tralf
Übersicht Z1000 (ab 14) / Z1000 R Edition (ab 17)
tralf
(Modellbezeichnung 2014-2016 (Euro 3) ZRT00F, mit ABS: ZRT00G)
(Modellbezeichnung ab 2017 (Euro 4) ZRT00H)
:arrow: mehr Bilder
Farben [R.H. Lacke Farbcode]
2014
  • Flat Ebony Type 2 [45L] / Metallic Spark Black [660]
  • Candy Burnt Orange [17L] / Metallic Spark Black [660]
  • Special Edition: Golden Blazed Green [40R] / Metallic Graphite Gray [45W]
sml_gallery_1621_1783_8702.jpgsml_gallery_1621_1783_232622.jpgsml_gallery_1621_1783_67988.jpg
2015
  • Metallic Spark Black [660] / Flat Ebony [32N]
  • Golden Blazed Green [40R] / Metallic Spark Black [660]
  • Metallic Carbon Gray [51A] / Candy Burnt Orange [17L]
sml_gallery_1621_1783_48051.jpgsml_gallery_1621_1783_151753.jpgsml_gallery_1621_1783_99659.jpg
2016
  • Metallic Matte Graphite Gray [??] / Golden Blazed Green [40R]
  • Pearl Stardust White [25Y] / Golden Blazed Green [40R]
  • Sugomi Edition: Metallic Spark Black [660] / Candy Crimson Red [53R]
sml_gallery_1621_1783_117157.jpgsml_gallery_1621_1783_186967.jpgsml_gallery_1621_1783_97850.jpg
Performance Edition
2017
  • Metallic Spark Black [660] / Golden Blazed Green [40R]
  • Candy Burnt Orange [17L] / Flat Ebony [32N]
  • R Edition: Metallic Spark Black [660] / Metallic Graphite Gray [45W]
sml_gallery_1621_1783_93573.jpgsml_gallery_1621_1783_12110.jpgsml_gallery_1621_3107_168488.jpg
Performance Edition
sml_gallery_1621_1783_28842.jpgsml_gallery_1621_1783_154182.jpgsml_gallery_1621_3107_197150.jpg
2018
  • Emerald Blazed Green [60R] / Metallic Carbon Gray [51A]
  • Pearl Storm Gray [36S] / Candy Surf Blue [25V]
  • R Edition: Metallic Matte Carbon Gray [] / Metallic Spark Black [660]
sml_gallery_1621_1783_199783.jpgsml_gallery_1621_1783_86610.jpgsml_gallery_1621_3107_53461.jpg
2019
  • Metallic Flat Spark Black / Metallic Matte Graphite Gray
  • R Edition: Metallic Flat Spark Black / Metallic Matte Graphite Gray
19ZR1000H_40RBK1DRF1CG_A.thumb.jpg.cf128ded19fefd27f733aad3b2d07d18.jpg19ZR1000HKF-PERFORMANCE-front.thumb.jpg.26c8740af9092e542d7b01173484bee2.jpg
2020
  • R Edition: Metallic Spark Black / Pearl Storm Gray / Emerald Blazing Green
19ZR1000H_40RBK1DRF1CG_A.thumb.jpg.cf128ded19fefd27f733aad3b2d07d18.jpg19ZR1000J_40RBK2DRF1CG_A.thumb.jpg.b998cde54d4e73261c4c5fa2b31fe811.jpg
Technische Spezifikation
  • Motortyp: Flüssigkeitsgekühlter Viertakt-Reihenvierzylinder
  • Hubraum: 1.043 cm³
  • Bohrung x Hub: 77 x 56 mm
  • Verdichtungsverhältnis: 11,8:1
  • Ventil-/Einlasssystem: DOHC, 16 Ventile
  • Maximale Leistung: 104,5 kW (142 PS) bei 10.000/min
  • Leistungsbeschränkte Version: Leistungsumrüstkit 72 kW (98 PS) gegen Aufpreis
  • Maximales Drehmoment: 111 Nm bei 7.300/min
  • Gemischaufbereitung: Kraftstoffeinspritzung: Ø 38 mm x 4 (Keihin) mit ovalen Sekundär-Drosselklappen
  • Zündung: Digital; Zündkerzen Erstausrüstung: NGK CR9EIA-9
  • Starter: Elektrisch
  • Schmiersystem: Druckumlaufschmierung, Nasssumpf
  • Getriebe: Sechsganggetriebe
  • Endantrieb: Dichtring-Kette; Erstausrüstung: Enuma EK525ZX 112 Glieder
  • Kupplung: Mehrscheibenkupplung im Ölbad, mechanisch betätigt
  • Rahmentyp: Aluminium-Doppelprofil-Rückgratrahmen
  • Lenkkopfwinkel/Nachlauf: 24.5˚/101 mm
  • Radaufhängung, vorn: 41mm Upside-Down-Gabel, Druckstufendämpfung und Zugstufendämpfung stufenlos einstellbar, Federbasis: voll einstellbar
  • Radaufhängung, hinten: horizontal angeordnetes Back-Link-Gasdruck-Zentralfederbein, Zugstufendämpfung: stufenlos einstellbar, Federbasis: stufenlos einstellbar
  • Radfederweg, vorn: 120 mm
  • Radfederweg, hinten: 122 mm, ab 2017: 135 mm / R Edition 131 mm
  • Reifen, vorn: 120/70ZR17M/C (58W) Erstausrüstung: Dunlop D214 Luftdruck: 2,5 bar
  • Reifen, hinten: 190/50ZR17M/C (73W) Erstausrüstung: Dunlop D214 Luftdruck: 2,9 bar
  • Bremse, vorn: semischwimmend gelagerte 310 mm Doppelscheibenbremse im Petal-Design, radial montierte Vierkolben-Monobloc-Festsättel
  • Bremse, hinten: 250 mm Scheibebremse im Petal-Design, Einkolben-Schwimmsattel mit Zugankerstrebe
  • Lenkwinkel, links / rechts: 29˚/29˚
  • Nachlauf: 101 mm
  • Abmessungen (L x B x H): 2.045 mm x 790 mm x 1.055 mm
  • Radstand: 1.435 mm
  • Bodenfreiheit: 140 mm
  • Sitzhöhe: 815 mm
  • Tankinhalt: 17 Liter
  • Gewicht fahrfertig: 221 kg
  • Sicherheitssystem: ABS
  • Scheinwerfer automatisch Ein (AHO): Ja
  • Übereinstimmung mit EU-Abgasnorm: EURO 3, ab 2017: EURO 4
  • CO2 Emissionen: 151 g/km
Übersetzung
  • Primär 1,627 (83/51)
  • 1. Gang 2,600 (39/15)
  • 2. Gang 1,950 (39/20)
  • 3. Gang 1,600 (24/15)
  • 4. Gang 1,389 (25/18 )
  • 5. Gang 1,238 (26/21)
  • 6. Gang 1,107 (31/28)
  • Endübersetzung 2,867 (43/15)
  • Gesamtübersetzung 5,165 im obersten Gang
Features
  • LED-Scheinwerfer
  • Sugomi-Design
Modellpflege
2014 (Neupreis 12.195€, Special Edition 12.395€)
2015 (Neupreis 12.195€)
2016 (Neupreis 12.195€, Performance 13.495€, Sugomi Edition 13.395€)
- Anti-Hopping-Kupplung
- Servo-Kupplung (leichtere Betätigung)
Performance:
- Akrapovic 4 in 2 Auspuff
Sugomi Edition:
2017 (Neupreis 12.395€, R Edition 13.895€)
- Ganganzeige
- Euro 4
- Spiegel mit verbesserten Einstellmöglichkeiten
- neues Blinkerdesign
R Edition:
- Brembo M50 Bremssättel
- Brembo 310mm Bremsscheiben
- Stahlflex Bremsleitungen
- Öhlins S46DR1S Federbein
- geprägter Sitzbezug mit Z-Logo
- Aufklebersatz
2018 (Neupreis 12.495€, R Edition 13.895€)
R Edition:
- siehe 2017
- LED Blinker vorne
2019 (Neupreis 12.845€, R Edition 14.345€)
R Edition:
- siehe 2017
- Akrapovic Slip-On
- Tankpad
2020 (Neupreis 12.945€, R Edition 14.445€)
R Edition:
- siehe 2017
- "Fat-Bar"-Lenker aus Aluminium
Performance
Beschleunigung:
  • 0 –100 km/h: 3,2 s
  • 0 –150 km/h: 5,6 s
  • 0 –200 km/h: 10,0 s
Durchzug:
  • 50-100 km/h 3,7 s
  • 100-150 km/h 3,7 s
Verbrauch:
  • Durchschnitt 7,2 l/100 km
  • theoretische Reichweite Landstraße 236 km
Wartung
http://www.z1000-forum.de/files/file/248-%7B%3F%7D/
http://www.z1000-forum.de/files/file/259-%7B%3F%7D/
Fahrwerk-Setup (Empfehlung (PS) / Werk (68kg))
Gabel:
  • Vorspannung: 28 mm stat. neg. Federweg (voll entspannt) / 6,25 Umdrehungen nach rechts (rein, von nicht vorgespannt)
  • Druckstufe: komplett offen / 4,25 Umdrehungen offen (nach links, wenn rechts Anschlag)
  • Zugstufe: 2,5 / 2,5 Umdrehungen offen (nach links, wenn rechts Anschlag)
Federbein:
  • Vorspannung: 8 mm stat. neg. Federweg / 185,3 mm Länge der Feder
  • Druckstufe: nicht einstellbar
  • Zugstufe: komplett offen / 0,75 Umdrehungen offen (nach links, wenn rechts Anschlag)
Leuchtmittel
Bezeichnung: Betriebsspannung / Leistung / Fassung
Fernlicht + Abblendlicht: LED
Standlicht: LED
Kennzeichenbeleuchtung: 12V / 5W / BA15s oder R5W
Blinker vorne (li + re): 12V / 21W / BAU15s oder PY21W
Blinker hinten (li + re): 12V / 10W / BAU15s oder RY10W
Bajonettfassung:
Position der Pins: BAU = "9 + 4 Uhr", BA/BAY = "9 + 3 Uhr", BAX = "9 + 2 Uhr"
Angaben ohne Gewähr: Die Leistungswerte sind aus dem WHB und die Sockel aus den Bildern mit möglichen Lampenarten zugewiesen.
Mehr Informationen :arrow: http://kawasaki.de
:arrow: Datenblatt
This topic is now closed to further replies.
